Treo and Tomtom Home
I'm not sure but I think TT Home is for PNA devices only (ie Go, XL One series). To add or remove maps or other TT related isues, you'll have to use the software included in the TT CD's, which should have been included when you purchased your Treo. That was how I was doing it when I had my Qtek S100 three years ago.
Which version of Tomtom Home are you using? As far as I can tell, only version 1.3 and 1.5 support the SD cards(because the devices connect via USB and identify themselves when plugged in).
In Tomtom home 1.3 or 1.5, you can click on "Device" at the top, then change device to select the SD card(if you have it plugged in via a card reader).
Vince01
