Tomtom rider 500 charge cable to USB
Rider500
Hello all.
I'm looking for the charging information/ speciations for my rider 500 GPS so I can see if its a viable option to make an micro usb adaptor sub-lead for when I don't need the GPS.
My phone requires 5V 1.5-2.1amp charging. I want to know if the tomtom rider cable which is hard wired into my bike is OK to do this, if so I've found the two connectors online and will make my own sub-lead to suit.
Thank you in advanced for any information.
If I am understanding you correctly, BE CAREFUL! Are you talking about connecting directly to this plug?
I believe the voltage is stepped down for the Rider models from +12 to +5 in the mount, not inside the connector housing of the TomTom supplied cable! Be sure to check the voltage at that point you plan to connect your home brew adapter!
Bonjour, je n'ai pas encore une grande expèrience en matériel tomtom, mais il me semble que ce cable est à raccorder sur le 12 volts de la moto, donc au bout du connecteur c'est aussi 12 volts. Comme l'a si bien dit canderson ATTENTION !
@loulou
This is an English language forum. Please use Google translate or similar for future posts so all here can assist. Thanks.
Hello, I don't have much experience in tomtom equipment yet, but it seems to me that this cable is to be connected to the 12 volts of the motorcycle, so at the end of the connector it is also 12 volts. As Canderson so aptly said WARNING!
@loulou
Il s'agit d'un forum en anglais. Veuillez utiliser Google Translate ou similaire pour les futurs messages afin que tous ici puissent vous aider. Merci.
Sorry but i have not find how to use Google translate in this forum. If you can help me... thank you.
1. In your browser, type: google translate
2. When it opens, select FRENCH for the language on the left side and ENGLISH on the right side.
3. Type what you desire in the appropriate space. The translated text will appear on the right side.
4. Copy the translated text and paste it here.
1. Dans votre navigateur, tapez : google traduction
2. Lorsqu'il s'ouvre, sélectionnez FRANÇAIS pour la langue sur le côté gauche et ANGLAIS sur le côté droit.
3. Tapez ce que vous désirez dans l'espace approprié. Le texte traduit apparaîtra sur le côté droit.
4. Copiez le texte traduit et collez-le ici.
Hello, thank you for your help. I knew this way of doing things, but I thought I would find a similar function integrated into the forum. So no more problem. Thanks again .
In english now : Hello, I don't have much experience in tomtom equipment yet, but it seems to me that this cable is to be connected to the 12 volts of the motorcycle, so at the end of the connector it is also 12 volts. As Canderson so aptly said WARNING!
It's 12 volts to the support then 5 volts out of the support.
avec cette photo tout est clair
I am glad it is fixed for you but PLEASE correspond in English in this forum.
It is OK to write in ones own language too.
Je suis content que ce soit réglé pour vous, mais VEUILLEZ correspondre en anglais dans ce forum.
Il est également acceptable d'écrire dans sa propre langue.
Type your text here then copy and paste it in TomTomForums. Then, click the copy icon on the right side bottom and paste it in the forum.
If you want to make it easy for others, highlight you language entry in the forum and click the " (quotation mark = quoted text) at the top and your original will be boxed in.
Saisissez votre texte ici, puis copiez-le et collez-le dans TomTomForums. Cliquez ensuite sur l'icône de copie en bas à droite et collez-la dans le forum.
Si vous souhaitez faciliter la tâche des autres, mettez en surbrillance votre entrée de langue dans le forum et cliquez sur le " (guillemet = texte cité) en haut et votre original sera encadré.
31Den
