TomTom Home and 910
San Diego, CA
The TomTom web sites states: "Using TomTom HOME, you can run your device on your computer: plan routes in advance, add Favorites, change settings, etc. Simply connect your device to your computer, then click "My device" in TomTom HOME." Their example is a GO 700. When I try this on a dual or single processor G4 Mac with my 910 I get the message "At this time there is no component available that is compatible with your TomTom device."
Does this feature work with the 910? Is this a Mac problem".:confused:
TIA
Does not work on a Mac. Sigh. HOME has a long way to go on the Mac platform.
Aphid2020
