Tom Tom 6100 Speed Camera Reporting
I recently purchased a 6100 and when I test to report a speed camera it accepts the instruction and says thanks but when I drive back through the point there is no warning. If I go through a fixed camera site it warns me so that part is working fine. On my old 2050 I could test it and it worked OK. Why won't the 6100 do the same ?
Are you referring to a mobile speed camera?
Later you say it is working OK with fixed cameras.
I don't know if it is correct but I have read that mobile speed camera notations only stay up for 3 hours unless reported again by others.
Yes I am referring to mobile speed cameras and I am aware that they are only on for a limited time but if I do a " test " report then drive back through in 15 minutes my 6100 does not respond but my 2050 does.
Well, report it to support:
United Kingdom
02079 490 134
ZorroNY
