I have two XL340's - a year-old 340s and a brand new 340tm. I used the latest map guarantee to update my map, and I moved a copy of our favorites to the new gps. I had just entered my activation code for the map subscription when TomTom HOME told me there was a critical software update I should install, v. 2.8.0.2146.
After installing that update, when HOME opened, it tried to check to see if I needed any updates and immediately I got an error "We're sorry, but HOME can't complete that task. Please try again later, or contact customer support. For problems with items that are stored on your device, we advise you to remove and re-install the item." When I looked at the details, it showed my map file as the problem.
When I close the error message after sending a copy to tomtom, HOME seems to operate OK, but no matter what menu button I choose, it gives me the same darn error before taking me to my choices. I haven't been checking the details since the first time, but have been sending the reports to tomtom.
I rebooted, but still get the same error. I tried using the older gps with the same results, so it isn't confined to my new device. Next, I went to another computer which still has HOME 2.7, and I do not get these error messages with either gps. I road-tested the new gps, and it is working just fine: favorites transferred correctly, safety camera alerts are working, and everything seems normal.
Has anyone else experienced this problem? I don't think there's anything wrong with my actual GPS; the problem seems to be with the HOME update. Should I uninstall HOME and reinstall? Any other ideas?
