Poi conversion question.
I just found a websight that gas a bunch of cool pois in csv frmat, and I have been able to use an online converter to be able to use them on my tomtom, but there is one that is probably the most usefull to me that I cant get the converter to work on. Can someone help me to get these pois to the ov2 format? Here is the link to the file I want...http://www.poi-factory.com/poifiles/us/lakes
Stevel52
