Please need fast Help - XXL 550TM or VIA 1535TM
Hello guys, just fast a question
which GPS better the XXL 550TM or the VIA 1535TM??
thanx
Any chance we could talk you into the XXL540TM instead of the XXL550TM? I think you'd find that it supports a wider range of features than either of the other two.
I have the XXL540TM, which I consider a better device than the XXL550TM because the XXL550 is basically a crippled version of the XXL540. I believe that you can currently get the XXL540TM for a price comparable to the price of the XXL550TM. so I would encourage you to look at that model.
I also have the GO 1535 LIVE, which is similar to the Via 1535 but has more features. However, with the exception of the LIVE features, I consider the XXL540TM to be a better choice than the GO 1535 LIVE. Since the Via 1535 does not have LIVE capability, it is my opinion that the XXL540TM would be the better choice.
With best wishes,
- Tom -
ClemFandango
