i cant access the device..i dont know if i did this wrong, when i first launch tomtom at my pc it asks me to update some files, i also update the latest map, i tried to install it but it says it has no free space, so i deleted the old map ( i made a back-up for the map ) and tried to install the new map, so when i try to add a new map it says the map cant be used in the device untill its activated first
btw when i tried to add a map the file size is around 1.7 gb ( old map?), and the new map i download is around 1.6 gb, but when i add, only map appears is the 1.7 gb which is the old map right?
edit: ok i transfer the latest map to FromDevice folder, and installed it, but it gives me an error it says "problem with map, you cannot use this map on this device, usa_canada_mexico_p-165", also by downloading the file it has a activation in a zip file
