Help! Trouble adding maps to SD card in Palm Treo
I lost my SD card which housed all my maps. I purchased a new card and loaded TOMTOM Application from the Application and User Manual CD. I then began loading the maps. The first map loaded successfully to the SD card but all subsequent attempts to load additional maps returns the following error:
Starting installation of 'west.ini' and 'west.cab'.
Trying to install west to Palm folder West-Map on SD Card.
An internal error occurred (Error number: 7) (Cabinet extraction error).
Deleted 'west.ini' and 'west.cab'.
Help!
Thank you,
tony1260
