Help creating route
Whenever I create a route, TomTom brings me a specific way. Even if I click the alternate route I can't go the way I want. For example, I do NOT want to take the George Washington Bridge to get to the New York State Thruway but would rather go via the Whitestone Bridge. I can't figure out how to tell TomTom this. Bridges are not listed as POIs. Can anyone please help me?
Thanks in advance,
Dov
In the 'Find Alternative' section, choose 'Travel Via...'. Then choose 'Point on map' and zoom in real close to accurately place the cursor just before the bridge you want. Make sure that the cursor is in the correct lane of the highway.
With 'Travel via...', you can only place one point. If you need more than one, then you will have to build and itinerary.
garoutte07
