Going over the speed limit and the red box
Ontario, Canada
Sony XNV-660BT
Hi there,
I have a TOMTOM unit and it used to be when I went about 7 km/h over the speed limit on the device a square would turn red. I noticed that since I've done updates that this doesn't occur anymore.
Anyone know why this is? Is there a way to put it back to the original way again?
Thanks,
grcboy77
Check the settings screens...
In "Safety settings" there should be one for "warn when going faster than allowed". If you tick that, it should switch on the "red box" on-screen alert and the next page of settings should allow you to select an audio alert (or silence) too.
williamcharl
