Go 930 problems
Posted - 03/22/2009 : 03:08:00 Show Profile Reply with Quote
HI
My GPS' system info is below
I have a three problems
In HOME, I can use 'Back Up and Restore" and "operate my GO" - I get a message saying "You can not use this feature because it is not supported by your device"
The third problem is that from HOME/Show Contents/voices - the 4 English voices say "this item cannot be used on the current version of the the TomTom application on your "and their 'More info's say "this item does not work on your device" even though they are working
Does any one have any ideas?
Preston
Profile folder = C:\Documents and Settings\Preston\Application Data\TomTom\HOME\Profiles\qwnkh9ht.default
Installation folder = C:\Program Files\TomTom HOME 2
Plugins folder = C:\Program Files\TomTom HOME 2\xul\plugins
Data folder = C:\Documents and Settings\Preston\My Documents\TomTom\HOME
Version = 2.6.0.1525
Language = en-US
User name = xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Login status = User is logged in
Server = https://home.tomtom.com/redir/
Connection settings = Direct connection to the Internet (default)
Installed add-ons = Map status indicator 1.6, TomTom HOME default theme 1.0.1, Emulator 8.300.9732.1
Name = TomTom GO 930
Device Code = xxxxxxxxxxxx
Serial number = xxxxxxxxxxx
Capabilities =
Storage devices = Hard disk (G:) - Active|Hard disk (H:)
Installed Items = program/Navigator 8.302, phonedb/connect2internet 15, suspendscreen/antitheftw 1, itinerary/233_hollow_rd__east_stroudsburg_pa 0, itinerary/Kinder_la 0, carsymbol/Honda_CR-V 1, carsymbol/-default 1, carsymbol/Arrow Yellow 1, carsymbol/BlueCar 1, carsymbol/ClassCar 1, carsymbol/FamilyCar 1, carsymbol/FinnedCar 1, carsymbol/GreyCar 1, carsymbol/Oldtimer 1, carsymbol/RaceCar 1, carsymbol/RedCar 1, carsymbol/SportsCabrio 1, carsymbol/SportsCar 1, carsymbol/SUV 1, carsymbol/YellowCar 1, loquendovoice/English (US) - Dave 710, loquendovoice/English (UK) - Kate 710, loquendovoice/English (UK) - Simon 700, loquendovoice/English (US) - Susan 700, satimage/usx 2, map/North_America 825.2157, poi/Birding_sites 0
Error incident IDs = 9468835
* Computer info:
Operating system: Windows XP (build 2600, Service Pack 3)
Free memory: 659456000 bytes
User home directory: "C:\Documents and Settings\Preston\My Documents\"
Home volume space: 29986 / 76308 MB
Temporary directory: "C:\xxxxxxxxxxxxxxxxxxxx\Temp\"
Temp volume space: 29986 / 76308 MB
Install directory: "C:\Program Files\TomTom HOME 2\xulrunner\"
Install volume space: 29986 / 76308 MB
External volume devices: G: [G:] 1927 / 3878 MB ; H: [H:] 1520 / 3832 MB
OS login name: xxxxxxxxxxxxxxxxxxxx
Host name: xxxxxxxxxxxxxxxxx
Date and time: 2009-03-21 20:42:03
* HOME info:
DLL Version: 2.6.0.1525
MapShare DLL Version: 2.6.0.1525
Language: en-US
* Connected device: ""
Type: "go930_4096"
Serial: "xxxxxxxxxxx"
MapShare information:
Patch format version: 2.4
Map patch downloads: true
POI patch downloads: true
Feedback email address:
Patches to upload: 0
POI Subscriptions: 7367, 9364, 7369, 7313, 7311, 7380, 7395, 7383, 9910, 7341, 9906, 7342, 9352, 9367, 9363, 7319, 7385, 7352, 7366, 9911, 7321, 7314, 7376, 9935, 7317, 9365, 7339, 7324, 7312, 9930, 7315, 9361, 7373, 7374, 7318, 7316, 9927, 7320, 7322, 7365, 7377, 7397, 9357, 9360, 9369, 9371, 9373, 9374, 9375, 9379, 9902, 9913, 7310, 7326, 7337, 7338, 7349, 7360, 9362, 9377, 9378, 9380, 9800, 9801, 10001, 10002, 7392, 7384, 7372, 10012, 10013
IL #3: 'Hard disk' 1927 free/3878 total MB Block Size 32768 Media Name 'Storage' serial $bcbbd56f, Writable
IL #4: 'Hard disk' 1520 free/3832 total MB Block Size 4096 Media Name 'InternalMemory' serial $145c7c8f, Writable
GO 930 Problems - Updated
I meant to say "In HOME, I can't use"
I got an upgrade to HOME just after I wrote the message - I am using v2.6.1.549 now - situation did not change
The computer voices are working - but HOME shows the 4 English computer voices as not being suitable
Well, using the emulator (Operate My Go), does not allow for the use of computer voices. Is that the issue?
Thanks for your reply
I can not use 'operate my GO" and 'Backup/Restore' using the emulator - that is the problem. The computer voice issue is really an aside - the emulator tells me that they are not suitable for my device
Check in Control Panel-->Add/Remove Preograms whether you have dot net framework installed. you probably do, but just in case, the link to get it is here.
Try a pin reset on your unit, dock it again, and see if Home works now.
A pin reset (known as a soft reset) will likely wipe out your time on the unit, nothing else. A hard reset (restore to factory defaults) wipes out all your settings you made in the unit.
If you go to preferences --> set time --> (page 8) and, after selecting the view option you want to see, there is a button called 'sync'. Click that for the current minutes. At worse, you may have to manually set the hours value.
Problem resolved
Solution was quite simple really - I unloaded the maps and re installed them
Worked oK
Thanks for your help
Preston
garoutte07
