Do i need TT home.
UK
none
Hi, i have replaced my stolen 720t with a 1005 world, do i still need Home or delete it to free space on my laptop.
No, you no longer have any use for TomTom Home. If you have not yet discovered the 'replacement' application for your PC for that 1005, you can find it here:
https://www.tomtom.com/en_gb/mytomtom/getstarted/
While you're at it, you can also clear out all of the 'historical' info you collected for your 720 by deleting the entire My Documents/TomTom folder. Probably free up a good bit of disk space there.
BigL
