Changing default car icon in 2d view
Aurora,Ontario
Go 920 v8.010 North A map
Is there any way to change the default blue arrow car icon in the 2d view?
Maybe rename the yellow arrow icon to "-default"?
Anyone had any luck with this?
Thats changing the car icon on the 3D map which is a Navcore supported feature that works, the OP whant to change the icon when using the 2D map which AFAIK isn't possible to do - Mike
abowen
