Battery Specs.
Ingleside, TX
One XL-S
Does the XL and the XL*S use the same battery? Can anyone tell me a good place to obtain a replacement battery for the XL*S model?
Thanks,
Send a pm to GAW and canderson. They are amongst the battery experts here. If anybody can help you, they can, I suspect.
They cannot be sure of the battery specs. Does anyone know if this is the same battery as is in the One XL?
I would think it was the same. From what I know (very little), I think the XL*S is the same dimensions as the XL, the change being in the software that allows text-to-speach for the 'newer' model.
Anyone know for sure? Or the number of the XL*S battey?
Thanks,
sisproj
