hi
can anyone help ?
i changed the battery in my tt go 720 and that's when all the problems started
firstly the tt started looping on start up i managed to cure this by removing the map settings cfg file from the western Europe map then a problem switching the unit off i found for some reason there were 2 copies of maps on my unit so i removed one and that cured that problem ,i started to use tt in my car and everything was working good then i saw in the details screen the Bluetooth icon with a red x on top of it so i went to the Bluetooth settings in the menu and tried to enable and search immediately the red screen came up "Bluetooth error do you want to try again" pushed yes and it just hung for ages so eventually i reset the unit and guess what im back to square one "looping" so i removed the map settings cfg file again and it started working again (still no Bluetooth) one thing i have noticed that each night i turn it on it seems to boot up like from new ie hard disk load up screen and then welcome to tom tom go 720 but doesn't ask me to renew all the settings (thank god) occasionally it will just show the tom tom screen (road with night background (splash screen?)) and boot up a little faster but if i ever go near the Bluetooth settings page it has to be all reset again
i was wondering (thinking out loud) what about firmware update ,renew software format disk (obviously after backing up everything) but this is a little out of my comfort zone so a little bit of guidance would be appreciated if i was to go down this route
many thanks for your time any reply's gratefully accepted
can anyone help ?
