just an FYI, attached is the TT Support instruction - might help someone else! Note they suggest Explorer b/u, not HOME2
STEP 1 - Creating a Manual backup of your TomTom
- Open 'My Computer', you will see the TomTom as a removable storage device, e.g. TomTom (E
, double left click into it.
- Click on Edit -> Select All, then click on 'Edit -> Copy'
- Go to your Backup folder on your desktop that you have created, double left click into it and click on 'Edit -> Paste'
IMPORTANT: Please only continue with Step 2 if you have made a complete Manual back up of your TomTom without any error messages. If you do get an error message, please contact us before continuing.
If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2 - Format the hard-disk,
? Open 'My Computer'
? Right click on the TomTom drive (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
? Please make sure that quick format is not selected.
? Click on start.
? Once the format is complete, use the ?Safely Remove Hardware? icon in the bottom right hand corner of your computer to disconnect your TomTom from the computer.
? Once disconnected, your TomTom will show a red cross.
? Reset the TomTom.
STEP 3 - Restore the Folders to the TomTom
? Connect your TomTom back to the computer and switch it on.
? Go to your backup folder in My Documents, double left click into it.
? Copy the following folder back onto your TomTom:
1- Your map folder(usually labeled Western and Central Europe or United Kingdom and Republic of Ireland)
2- The folder named 'zip'(United Kingdom and Netherlands only)
3- The folder named 'raster'(applicable on only some devices)
4- The folder named 'loqendotts' (applicable on only some devices)
5- The folder named 'ASR' (applicable on only some devices)
6- The folder named 'Vocalizer' (applicable on only some devices)
?Now disconnect your TomTom by using the ?Safely Remove Hardware? icon again.
STEP 4 - Now we need to delete the application files from your PC so that HOME will offer them as an update
? Click on Start in the bottom right of your PC
? Now select My documents -> TomTom -> HOME -> Downloads -> Complete
? Please delete the yellow Program folder.
STEP 5 - Update your device
? Reset the TomTom for 30 seconds.
? Connect your device to the PC and turn it on.
? Open TomTom HOME: Start->All Programs->TomTom->TomTom HOME 2.
? HOME will now load your updates (If this does not happen automatically, click on Update My ONE/GO/Rider on the main menu of HOME.)
? Make sure that only the application is marked with a green tick.
? Click on Update and Install.
? Once Installed, click on Done.
? You will now be prompted by HOME to restart your Device, just click ok.
? In the Top left of HOME, click on 'Device -> Disconnect Device'.
? Now please disconnect your TomTom from the computer and allow it to start up normally.
If you get ?No Maps Found? on your TomTom, please repeat Step 5.
STEP 6 - Run the Clear Flash Tool Twice
? Close HOME. (Make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen)
? Connect your TomTom to the computer. If it ask?s if you want to connect, please select yes.
? Download and run the clear flash tool from :
http://www.tomtom.com/updates/clear_flash/clear_flash.exe
? Now disconnect your TomTom (Safely Remove Hardware in the bottom right hand corner)
The Application is now installed, all corruption will have been removed and your TomTom will now be working normally again.
and all pigs fed and ready to fly...........
