Where do I buy a replacement hard case (the gps case) for a Tomtom Rider V2
rider v2
Hi I am after some information I where I would get a replacement shell for my Rider V2. The bottom flap has broken away from the rest of the case. Does any one know if you can buy the outer shell for a rider? The unit is working fine other than the broken flap. Thanks
Steve
Welcome to TTF. As to where to buy a replacement shell, perhaps a camera store where you are located will have a suitable case. Or eBay?
gardening_diva
