Vehicle dimensions on a Go Pro 520
Go Professional 520
Hi folks, I have recently bought a Go Pro 520 as I have started a job as a private hire minibus/small bus driver, driving a variety of vehicles up to a 33 seater.
However, when I try to enter the vehicle dimensions, the width always reverts to 2.60 metres regardless of what I have entered.
Obviously this doesn't fill me with confidence in the unit, so does anyone else have experience of this and can they suggest a remedy please?
I have exchanged my original unit but have encountered the same thing on the new one.
Any suggestions would be welcomed
Regards
Dave M
Welcome to TomTomForums.
Hopefully a reader with a GO Pro 520/620 can help you as none of us moderators has a Pro device.
The manual is at http://tinyurl.com/tuzu4kj [full URL below]
http://download.tomtom.com/open/man...refman/TomTom-GO_PROFESSIONAL-EU-UM-en-gb.pdf
On page 39 it shows to put in the vehicle type and dimensions.
You may also want to have a look at page 138, where Settings are explained.
NOTE: No matter what dimensions you enter for truck or bus, they are being ignored if the installed map is not a specific Truck Map.
Thanks for that response I'll check out the manual and see if it can resolve my issues
Regards
Dave M
pedaller
