I downloaded safety cams from tth ,I set the sounds and distances to warnings,enabled them .They don't show up on map or in pois.I am out of ideas.They do show up as being in device. Any ideas?????
Are the safety camera .ov2 files in the specific map folder? Under Preferences-->Show poi on map, have you checked the category? Did you dl an associated .bmp file with the safety camera .ov2 file? Are you sure the safety camera file covers your area of the country?
