Tomtom Menu customization issue
Tomtom Go 300; Nokia 7610 w/ Tomtom Navigator 5.20
I had created a customized menu using Tomtom Menu Builder. However the icon for connecting to mobile is greyed out.
When I remove the tomtom.mnu file it becomes active again.
Anyway I can fix that?
TTF
Spook,
I was using TASK_MENU_PHONE instead of TASK_PAIR_WITH_PHONE. That was the issue.
Thanks to you and Pedro
TTF
Of course, you just need the right command. Depends exactly which icon you mean, either mobile phone menu or create pairing.
IIRC these are:
From phone menu - TASK_MENU_PHONE
To create a pairing - TASK_PAIR_WITH_PHONE
I'm looking for the command for "call number" (not DIAL_POI) and "help me". Do you have them?
Thanks,
There is no command for "help me" - this has been discussed at length. The new features of Navcore 7 are not supported by custom menus. They use a different mechanism. Not sure about the other question since I never used the phone features.
Slater17
