tomtom home installation
I have recently bought tomtom one. I tried installing tomtom home on one of my machines running windows xp. I downloaded the executable from the tomtom website, and unfortunately, no installation window shows up. What could be blocking the installation from starting? Antivirus? Anti-Spyware? Thanks.
I looked at a similar thread and I downloaded an older version than updated. The only problem I have now is that the voices I downloaded for tomtom one are not showing up on my device.
If your model does not have a specific reset hole in the bottom of the unit, then yes.........
But check the link here and provide your specific model to see how to reset it.
Lesto
