tomtom go 550 digitiser replacement
Hi All !!
Desperate help from a newbie.. I need to change the digitizer for my tomtom go 550. I have managed to partly disasemble it up to the point where I have removed the 2 side panels, and pried the two halfs on the unit apart. I got hold of a disigtizer form ebay for my TT.
I am unfortunatly stuck now. I have no idea on how to remove the lcd from the front part to be able to replace the digitizer. Any help would be greatly appreciated!!
Thank you again!!
KK
Ahh.... when I saw the title of your post, I was going to reply to say that although the digitiser is available from eBay on it's own, I would think a better bet is to buy the whole screen assembly (for about ?30 in the UK).
that way, it's a simple ribbon cable to swap over.
But I see you've already bought the part.
Can't help, I'm afraid...:(
JayJayST123
