Tom Tom original splash screen with drum sounds
Anyone know how to get the original Tom Tom splash screen with the drum sounds back into my GO910.
I running North America map ver. 710.1609 and application Ver. 7.161.
I am using a splash screen in my photo folder of a Dodge Ram right now.
The drum sound actually doesn't come on with the splash screen, but before it.
I don't have the 910, but for the ONE the only way to get the drum sound is to do the soft reset (paperclip in the reset hole) or inserting/removing an SD card (don't know what the equivalent would be for the 910).
As for the original splash, i think you can get that from the tweak forum or get that in your backups.
which image are you missing? is it the splash screen with the 910 on the home dock in a white background?
Pedro2NR,
It's the splash with the black background and red hands with Tom Tom in white.
I believe you had posted it once somewhere.
abowen
