Routing Problems- Please Help
Hi- I'm using 7.221 w/ I think either 710 or 715 maps.
Lately, my 720 will tell, somewhere along my route, to go in circles. It will route me in a square. Left, then next Left, then next Left, then next Left. Or u-turn, then u-turn, etc.....
Any ideas on what's going on?
This is not just in one area. This happens now almost every time. Would this be a result of using mapshare? This happens all over south Florida...
Any ideas would be appreciated. Thank you.
Very odd. I would turn on only accept tomtom verified mapshare updates. See if that fixes it.
going around in circles
mine does the same in the northeast.
i figured the map just didn't know where a left turn was every once-in-a-while.
as for mapshare, i do not have "corrections reported by some" checked, but i do have all the others checked, including "reported by many" and "from a trusted source" (whatever that means).
are you suggesting i only use "verified by tomtom"?
Routing Suggestions 1
Routing 1
routing algorithm on Go 720 6
Horrible Routing 10
Mutiple point routing question, I think. 1
Routing issue TT2535 1
1605 Routing Assistance 7
Crazy routing 5
31Den
