Rider 2 MPH display question
Is there any way I can change settings so that the MPH display is larger and easier to read. I went through the preferences, but couldn't find any setting that would do this. Too small to read when riding as it is now.
If I remember rightly, on some models (I'm not 'au fait' with the Rider) you can add or remove details from the status bar, and in some cases if you remove something the remaining ones get a bit bigger.
That feature might have gone now though... I know it doesn't work on the most recent models.
germangholami
