problem with poi:s and tthome.
920T
i just got my first satnav and need some help...
how can you edit/add the additional info on poi files you have created, like poi url, opening hours, other info? i've seen this on pre-installed poi:s and there is a separate button to show that info.
can you use google earth placemarks somehow in tt with ALL the extra info still usable in tt?
in tt home, i cannot use the virtual 920, it gives out "Fatal error". i have the latest software in home and tt.
also in mapshare i can download the updates ok, but when comes time install them, i get "tthome cannot install map corrections to your device" error.
if anyone could help me with those i would be very happy!
1) It is unknown how to do this. You can add it as part of the description.
2)People have used google earth to make POIs. Search the forum and you will find your answer.
3)Do you use a Mac or PC? try to unstill HOME and reinstal it.
4)I sometimes get the same error. Try to update the GO again until it installs correctly.
Milancee1612
