Offroad Nav v1.7 -Geoid fix
San Jacinto,CA
GO 700
The Geoid fix offset for the area of operation @present location is minus
(-32.361) But when I check the Geoid fix radial button to Yes and input -32.4 when I try to save it reverts back to 0.0. Is there something I am missing ?
Keep us updated.
I inputed with text editor -32.4 and it shows up when I go to the setup screen, but as soon as I hit save it reverts back to 0.0 with geoid fix yes radial button selected. I have done this several times. Now if I just cancel it, it will remain, but is it really using the negitive attribute for the geoid offset ?
Or does it get it's information from Tripmaster ? which is set for -32.4
maybe this is a question for the programmer.
Yeah, possibly a bug? We'll wait for the developer to step in.
That's not a bug, that's a feature... (c) Bill G.
In fact, Offroad wasn't intended to be used under water. ;)
Maybe, I'll fix that in a later release. Meanwhile, you need to change the value with Notepad and never use the Save button.
Sorry roussillat, that's what I meant :) An unintended feature ;)
Nevermind......I just reinstalled over the top. v1.8b
Working great. Thanks Mr. R, great little program as we say in America
YOU D MAN ! keep up the good work !!!!!!!!!!
gardening_diva
