Next Major st name on right top corner (One 3rd ED)
I recently got TT One 3rd Ed. I updated it with latest map and latest 8.01 app. TT is working fine.
I want to remove the next street name which appear on top right corner of the screen. Any Idea, how I can do that ?
Yes, you can change that if you want.
  • Tap screen
  • Tap 'Change preferences'
  • find 'Status bar preferences' and tap it (right arrow a few times)
  • click 'done'
  • next screen shows 'Show next street name' and untick that.
  • Click done, done, done.
Hope this helps.
  • Tap screen
  • click 'done'
Hope this helps.
Thanks for reply. That removed (if already added) the next street from the *status bar* i.e the one which is displayed at the bottom of screen. I want to remove the one which is displayed at the top right corner. Any one with any more ideas ?
Thanks in advance.
The top right corner it usually where the "next highway/signpost" is displayed. Maybe uncheck that? Under Name Preferences I think....
31Den
