Need Help! MapShare's jacked
Just got a tomtom one 3rd and HOME is telling me that my maps are 28 weeks old and that i have 18,591 free MapShare corrections waiting, but every time i go to update it says this:
"Note
a problem has occurred
the following problem occurred. you can continue, but functionality may not be available.
MapShare patch distribution is temporarily unavailable"
I was able to update to the latest map and add new voices and images, but this is jacked
ALSO... when i try to operate my ONE in home... it downloads the new file, but always says that the installation of the new add-on failed
so what do i do about all this?
THANKS!
"Note
THANKS!
Welcome to the wonderful world of TomTom's crappy servers for that is where the problem lies. The message about having all the mapshares to dl is a faulty one. The usual 'solution' when you see something weird appear while in TTHome is to simply try again later (a couple of hours, perhaps the next day).
ZorroNY
