My TOMTOM is stuck in the help menu. Help! How do I get it out?
M matt5202 Joined Jan 24, 2012 Messages 2 TomTom Model(s) xl N14644 Jan 24, 2012 #1 My TOMTOM is stuck in the help menu. Help! How do I get it out?
dhn Moderator Joined Oct 1, 2007 Messages 23,453 Location Toronto Canada TomTom Model(s) Go 50; Go 520 Jan 24, 2012 #2 Try resetting the unit by holding the power button about 10 seconds till you hear the drum sounds if your model does not have a dedicated reset hole. But........ what 'help' menu are you referring to?
M matt5202 Joined Jan 24, 2012 Messages 2 TomTom Model(s) xl N14644 Jan 24, 2012 #3 Thanks- that worked!
