Help!!!! Tomtom one sd card empty!!!
Hello, and thank you inadvance for your help...
I plugged in my tomtom one gen one into the laptop and was beening reconized and then there was a proble with the installation, Tried to reinstall and now the sd card is empty, and now tomtom home will not recongize the tomtom, to be able to install the programs and the tomtom shows the sd card with a red X on it, i got this tomtom off my buddy and he doesnt have any disks that came with it, SO what can i do to get this running again.
Vince01
