go720 to truck cnversion help
Hi All,
Ok i would like to know if i can convert my tomtom go 720 to tomtom truck?
I currently have the regular map updates on yearly subscrption, i would like to convert my 720 to run the new truc software as i'm a lorry driver,
Question can i install truck software to the internal memory?
if so where can i get the software? and will my map updates contiune?
or will i have to purchase truck maps update subscription?
thanks
shark1e
You'll need to purchase the special tom tom truck map and install the specialized application to use in conjunction with that map.
Best thing is to call UK support.
Big Lenny
