GO 530 Green LED
GO530
Something I've just noticed whilst fault finding another issue. If I have my unit connected to the computer base unit or the car power supply the the Green LED works. If I'm operating it on the battery the unit appears to work fine but the Green LED doesn't come on. Any ideas?
The green led is to show that the device is connected to external power (hopefully recharging your battery).
rolandbogdan
