French help
Can someone help me translate these?
It's not French.
I think it's Italian.:p
Let me guess:
1- 'the file is write protected'
2- the OCX you want to destroy is used by other applications.
That's the best I could, hope there are some Italian members here that can help you.
I agree with lec510 on #1, but #2 looks like "The destination file is in use. Verify that all other applications are closed" or "Verify that all applications using it are closed"
Thanks Billclark.
without reading the directions... like any typical guy... I went ahead and tried the program anyway and it seems to be working just fine.
The install was in French, or Itialian...or whatever (something I certainly couldn't read) but the program runs in English... go figure.
dupete
