Busy planning route stuck
My 2 mos. old unit stays on BUSY PLANNING ROUTE and will not complete the task. I have tried off/on numberous times, satellite connection is on and off again most of time, very discouraged with my new XL.
Font, size slector doesn't work here either.
tks all
What model?
Did your unit work before and does not work now, or has it never worked correctly?
Is there any chance that this happened immediately after an update of some kind?
You do not say exactly which model, but it is likely that your unit resets by holding down the power button for between 20 and 30 seconds until you hear the drum sound. Reset your unit and advise.
Font size selector seems to work...
How were you trying to do it?
The text you want at a different size needs to go BETWEEN the {SIZE="x"} and {/SIZE} tags.
But no need to make a normal post larger than normal, we'll still read it just the same. :cool:
benley
