battery probs with go 710 ?
Hi I have just replacd the battery in my old faithful go 710 as it was charging ok but would not hold the charge for more than a couple of days ? After changing the battery it is just the same, as if something is draining the battery when it's turned off, any ideas ?:confused:
The TT won`t turn off, they just go in standby. This could explain your problem. My 720 usually last about 1 month without being plugged.
Use a pin to depress the reset button as that shuts the device off completely, the reset button is on the underside of the device adjacent to the electrical connector - If you do this the device will consume no power until its switched back on - Mike
theo972
