720: dwnloaded & installed a map. Map not appearing
tap
As mentioned in the title, I have the GO720 and purchased an Italy map today. When starting tomtom home, it listed the Italy update, which I promptly installed. After installation completed, I safely disconnected from my PC and turned on the Tomtom only to find that it was not listed in the change map section.
I am so confused as to what the problem may be. Is there any way to re-install the Italy update?
Any suggestions?
Montysa
