TomTom Home Ver. 2.2 is out today
29 JAN 2008
29 JAN 2008
Also under the tools | Map Share | Map Share preferences menu...Select Countires Tab...it says their are no countries available??? I assume that is why I can't get mapshare updates...anyone have any ideas?
Had this too. What I did was to delete all mapshare updates, unplug device, close home, plug device, open home and go to update to redownload all updates again. Then the setting windows you describe was showing info as it should.
Thanks for the info...just one question...how do I delete mapshare updates? actually, I don't think I have any...
Me too. Did the removal and home says no updates. Let's see what others are saying about this.
