Windscreen Mount Click-and-Drive
Go730
The official Tom Tom shop are selling on Amazon their windscreen click and drive mounting kits with charger and cable. However the right angled cable is micro-USB plug and the mount socket is USB-C judging by the reviews, everyone is sending them back - including me. Tom Tom have changed the mount USB but NOT changed the cable!!! anyone from Tom Tom on here that might like to explain. They must be getting a lot of returns...
On a cable, it's not possible to have a Micro-USB and a USB-C connector on the other side.
On a cable, either a Micro-USB or a USB-C connector is on the other side of the cable; it's a USB-A connector that connects to a charger or your computer's USB port.
This isn't an official TomTom forum, so there's no one from TomTom who can answer your questions.
Es ist nicht möglich, an einem Kabel einen Micro-USB- und auf der anderen Seite einen USB-C-Anschluss zu haben.
He didn't even write that.
He writes that the connector on the cable is a micro-USB and the socket on the holder, into which the connector is supposed to be inserted, is a USB-C port.
Ah, sorry, I didn't understand.
To avoid any errors, you must order the correct cable for your GPS model.
Thank you for reading my post! Yes that is what i said.
There were NO errors. I ordered precisely the goods that were stated, compatible with my model AS A KIT. It arrived in a TOM Tom Official box. At sometime the mount assembly has had the USB socket changed from a micro USB to a USB-C but they have NOT upgraded the cable which is micro USB Right-Angle plug with the standard USB-A plug on the other end. Very shoddy of them as I said they are getting MANY returns on their official Amazon page for this reason. Look at the reviews...
I'm lost ...
A typical recent review - no mention of incorrect cable end issues:
Reviewed in the United Kingdom on 21 February 2025
Style Name: Magnetic Mount + Charger GO, GO ProfessionalPattern Name: Mount Verified Purchase
Unbelievably fast dispatch . Brilliant item exactly as stated on the listing, tried and tested works perfectly. Thank you!
@Kevin Jordan
What GPS model do you have?
According to your explanation, you ordered a kit with a micro-USB cable and received a kit with a micro-USB-C connector instead. Is that correct?
No one is immune to poor packaging. Amazon had to exchange or refund it.
Then, when TomTom learned of this error, it had to recall the defective packs.
Bodman
