I think for safety purposes operating the device is prohibited inside an aircraft.I am going to fly from NY to LA this Christmas. Just wondering if I turn on the device during the flight, will my tomtom show my current position? Does anyone try this before????
Thanks... can't wait to try it...
Best thing to do if you are going to use it is to turn it on when you get on the plane while you are still at the gate so it can get the fix of sattelites.
Some electronic equipment is considered acceptable for use during flight and other equipment is not - and the rules can sometimes vary with the country and/or the airline. Most operators will allow a GPS in flight, but some may not, so it's a good idea to check before you turn one on.Best thing to do if you are going to use it is to turn it on when you get on the plane while you are still at the gate so it can get the fix of sattelites.
Sorry to revive an old (but interesting) thread.
I tried it on a Southwest flight this week but couldn't get it to lock onto a signal for over 5 minutes. It was a Boeing 737-700 aircraft. Held the back of the 540TM against the window and everything - no dice.
According to Southwest's list of "approved electronic devices", GPS devices are permitted above 10,000 feet. So according to that, you shouldn't have it on while the plane is taking off or landing.
