Variable Speed limits for different vehicles
Go CamperMax
Hay all wouldn't it be great if when you put in your vehicle details in. IE Motorhome, and you put in the weight the speed limit adjusts to that vehicle. My Motorhome is 4.25 ton so over the normal 3.5. My speed limits are lower so 30, then a 60 road is 50, duel carriageway is 60 then motorway is 70. Be nice if it would come up with those speeds instead of the normal car one's. Is there anywhere we can make suggestions on the TomTom site ??
Yeah i think you can but only max speed not on different roads as mine is over 3.5 tons i can only do 50 on A roads but i can do 70 on a motorway 🤷🏻
I agree, UK limits for weights and towing different to cars. My new camper only shows the car limits. My old tomtom trucker had different speeds for the different vehicle details so it must be technically possible and only a software update.
Steve321
