- Joined
- Oct 21, 2013
- Messages
- 12
- TomTom Model(s)
- GO 300, Start 60,
I've just bought a secondhand GO6200 (Serial no. ZA6318101165 (0) ) and should like some advice on how I should set about using the unit. Should I perform a factory reset and then try to add the device to my own My Drive account? If I do this, do I first need to contact TomTom support and request that they change the e-mail address registered to the unit? If I change the registered address, is there any risk that I will lose any of the current subscriptions? Might I do better to just leave it as it is?
I understood from some product descriptions that the GO6200 had lifetime Traffic and Speed Camera updates but some references suggest that this is only a feature of the GO6250. Did some GO6200s have lifetime subscriptions? My unit currently says 'You have a TomTom Traffic subscription' and ' ... Speed Camera Updates subscription'. Should it say 'lifetime subscription', if this was the case?
