Originally posted in error on the iPhone TT forum - posted again here
Tom Tom support has not been able to fix my problem (as follows):
1. Pair TT with iPhone (no problems experienced)
2. Connects automatically whenever TT and iPhone are switched on.
3. Problem arises if you use the navigation to go to an address
4. Set destination address
5. Connection between TT and iPhone works fine until TT and/or phone is switched off.
6. Next time TT and iPhone used, connection does not work.
7. Solution is to do the following:
(a) forget (delete) TT device on iPhone
(b) remove iPhone on TT
(c) switch off TT
(d) re-set TT using fine, blunt object
(e) re-pair TT and iPhone in usual way
(f) works fine until you set an address for navigation
Tom Tom support suggested that the TT should not only be re-set (as above) but that the 'flash reset' software tool be downloaded and used. Their instructions to me also included physical deletion of all files on the TT that are in the root directory of the TT (but not the various folders/directories. I did all of this but the problem persists. As it is, the TT is a good hands free phone, a good navigation tool, but NOT both
Any clues?
(c) switch off TT
Any clues?
