I updated my TomTom Eclipse AVN2210p with software version 6.552.7843 via the TomTom home application and have been having a problem ever since. I believe this update was called "TomTom application update for Eclipse and Toyota" in TomTom Home.
The unit works as expected, but when I turn my car off, the TomTom GPS unit will turn off, but then turns on again about 30 seconds later. It comes up with the initial green legal "GPS is dangerous while driving" message and then says "Welcome to TomTom" when I press "I Agree" like it did when I first purchased it. If I eject the TomTom from the dash and turn it off, it will start back up again. Sometimes it stays in this loop until the battery dies and it will finally shut off. Each time it restarts it works fine, GPS, Bluetooth Handsfree, Etc, It just does not want to shut off.
Before installing this version, when the car was turned off, the TomTom would turn off immediately and stay off. When the car was started again, it would immediately turn on and would not display the legal message.
The updated version seems to work with my new phone whereas the original version did not, so I would hate to have to use my backup as I would lose the handsfree ability. I have a Motorola Q9m.
I contacted TomTom support and got the general tech support run around. Asking me to to a soft reset which I did, and to remove and then reinstall the update which I did. Neither of these suggestions corrected the problem.
If anyone has experienced this problem or can point me towards a solution, I would greatly appreciate it!
Thanks,
Dan
Thanks,
Dan
