TomTom One v3 - Start up sound
I also would like to know this, but also have a question.... WHen I use the 2gb Sd card as the main hard drive... I get no start up sound at all... But when I use the tom tom 1 LE with out the sd card I get the start up sound. Now I have looked at both directorires on the tom tom sd card and the tom tom unit itself and all the file are the same.. But yet I get this difference when the sd card is in.. Any clues??? Thanks for your help in advance...
This thread has taken some time (nearly two years) - simple upshot is that you cannot modify the start up sound, the drum roll is hard coded in to the application which is what you hear when the device re-boots or post disconnection from the PC. There is no way to change this so forget about it - Mike
Eddy54
Member Recommended
