Hey guys, I have been searching the forum for over an hour now and i still haven't found a solution. I hope you guys can help!
I am trying to connect my tomtom via my usb bluetooth dongle and i haven't had any success with it.
My Bluetooth manager can detect the tomtom and when i try to "Trust" the tomtom it asks me to enter in the passkey so i put in "0000" with out the quotes and it still says it is unable to trust the device. I had tested it out with my cell phone and i can connect to my pc using my cell phone.
This is the funny part... When i use my cell phone to search for and detect the tomtom it finds the tomtom and when i try to pair it asks me for the passkey again so i put in 0000 and still nothing.
When i use my tomtom to "Mange phones" it actually sees and discovers my phone when i try to pair them it i have to go onto my cell phone and type in the passkey and it works like a charm.
When i use my tomtom to "Mange phones" to search for my PC it dosen't show up in the list unless i set my Bluetooth manager to "Palm Computer". It then says would you like to connect to "PC name" i select yes and it tells me that "Thre required features could not be found for this phone"..
I am truly stumped, I figure if anything i must pair the device's using the PC Bluetooth Manager so is there anyway to change tomtom's default passkey or am i doing anything wrong?.. Please let me know.
Thanks.
Thanks.
