- Joined
- Sep 10, 2013
- Messages
- 4
- TomTom Model(s)
- Android
I've just bought a new Camper Max (2nd generation) with a windscreen mount. Has anybody suffered from intermittent charging connection?
I ask this as my previous Camper Max (1st generation) had exactly the same fault. I even bought a new replacement windscreen mount for the first version but that also had the same fault.
I've had to turn off the battery setting to stop shutdown when power disconnected.
Is this a common fault and is there a workaround?
