This morning TomTom Home crashed on me and closed while my GO920 was in the dock connected. When I took it out of the dock, it wouldn't get past the splash screen. Did a reset on it, twice, still nothing. So, I connected it back to TomTom Home. I then deleted the application from the device, and reinstalled it, but nothing. So, I got pissed , went into My Computer, right clicked on the internal memory for the device and formatted it.
After it formatted I connected it back to TomTom Home. It downloaded the Application, and updated to v8.3. I then used LMG to get maps, I left it at that and came on in to work. I'm going to run home and check it at lunch.
Is there anything else I'll need to install to get it back to normal? Or is there a better way?
I tried the restore, but it kept saying something about an SD card that wasn't present. But it is, I even took the SD card out, but still nothing...
