I've successfully changed the startup screen and shut down image but I'm having trouble getting the sounds to work. I followed the instructions listed below and it doesnt work. Any ideas?
Creating a start-up sound
1. Record your sound in 22050 Hz Mono, with a sample size of 16-bit, using your preferred sound recording or editing software.
Tip: Your sound should be limited to a maximum of 3 seconds in length.
2. Save your sound as an OGG Vorbis file called splash.ogg. There are many free conversion tools online that you can use to convert .WAV and .MP3 files to this format, for example, Audacity.
3. Copy the file to the sounds folder on your TomTom navigation device.
The new sound replaces the sound that was currently installed.
